The relay provides power to the voltage regulator and the alternator field connection when the ignition is switched on, so the relay would be the first thing to check in my opinion. To do this:
WARNING - never mess with the wiring to the alternator with the ignition switched on or the engine running - bad things can happen…
With the ignition off, remove the Brown/Red and Brown/Purple (there will be two Brown/Purple wires sharing a single connector) wires from the relay terminals.
Short the two wires (Brown/Red to Brown/Purples) together using a length of wire, so that the relay is bypassed. This will power the voltage regulator and field coils of the alternator independent of the ignition switch. This should only be done as a temporary thing to test the relay, so disconnect them as soon as the test is complete.
Start the engine. Monitor the battery voltage - if the alternator is working you should see 14-14.5 volts across it. If you do, then the relay was the problem. If not, the voltage regulator is the likely cause (assuming the wiring is correct).
Turn the ignition off, and remove the shorting wire. If the relay is bad, but “clicks” when the ignition is turned on, it may just be a case of oxidized contacts. The relay can can be removed and the contacts cleaned up with fine emery paper to restore the fucntionality.
That begs the question f the accuracy of the rest of the wiring. Did Candiece’s father do the wiring or did he farm out that aspect of his restroation?
Looked back in the archives and didn’t see a picture of the setup for ottor switch on E-type S 1.5, Anyone have a picture by chance they could post up?
Depends. Early 1.5’s were series 1 4.2’s (one fan). These didn’t have relays. later ones were series 2’s, and had the S2 setup (two fans). If the S2 setup, then it’s different, depending on whether you have AC or not. Sooooo…what is it you are looking for
If so it must have been a very few series 1.5s that had the single fan setup. My car is the 80th Series 1.5 OTS produced and it has the dual fan setup.
As for Candiece’s question, a little clarification as to what she needs? If the question relates to wiring, it doesn’t matter which wire is on which terminal on the otter switch as it is simply an on/off switch (as others have stated).
