some ethanol 10% fuel FACTSâŚyou can look up, to verify:
ethanol fuel will absorb water many times more than no ethanol fuel, the water will separate and form a layer, this causes rust and corrosion. Ethanol fuel gains water over time, and also degrades over time. It is at first a high solvent and can dislodge old varnish that will then clog fuel lines, fuel filters and carbs. Then over time it loses its solvency and becomes gel like. Ethanol attacks certain older rubber compounds, older plastics and some metals. Maybe those are in your fuel delivery system, maybe not. The West Advisor
Join The Forum
Learn More
Busting Ethanol Fuel Myths
Keeping water out of the fuel system may prevent a call to TowBoatUS for a tow.
By Tom Burden, Last updated 6/1/2020
What are ethanol and ethanol-blended fuels?
Ethanol is used as an âoxygenateâ and is added to fuel to help reduce hydrocarbon emissions that cause air pollution. It is highly refined beverage (grain) alcohol, approximately 200-proof, that can be produced from natural products such as corn, sugar cane and wheat.
New technology allows ethanol to be made from cellulose-rich feedstocks including corn stalks, grain straw, paper, pulp, wood chips, municipal waste, switchgrass and other sources. Ethanol used for fuel has been denatured or rendered unsafe to drink by the addition of a hydrocarbon (usually gasoline).
The term âethanol-blended fuel,â or E10, refers to fuel that contains 10 percent ethanol and 90 percent gasoline. Similary, E85 refers to fuel that contains 85 percent ethanol and 15 percent gasoline. E85 is intended only for engines specially designed to accept high-ethanol content fuel blends, such as the Flexible Fuel Vehicles (FFV) made by some car companies. Not all states require gas pumps to be labeled to indicate the presence of ethanol in the fuel, so you may be currently using E10 fuel and not be aware of it. There have been efforts in Washington D.C. to introduce gas with 15 percent ethanol (E15). More on E15 and the potential dangers it poses for marine engines later in this Advisor.
How is ethanol made?
In the U.S., ethanol is typically produced by removing the starch or sugar portion of corn and fermenting it. The fermented starch is then distilled into alcohol. Excess water is removed, resulting in very pure, 200-proof, ethyl alcohol (ethanol). In some parts of the world, ethanol is made from a variety of raw materials. For example, sugar cane is used to produce ethanol in Brazil, while sugar beets and wheat straw are commonly used in Europe.
If you change over to E10 from non-ethanol gas, you should check for water in the water separating fuel filter. Carry spare filter elements, as ethanol is a solvent that loosens gunk in the fuel system.
Problems with the transition to E10 fuel
The most likely time for fuel problems occurs when you first begin using ethanol-blended fuel. When E10 is added to a fuel system that has been using non-ethanol gasoline, ethanol, as a new solvent, will tend to dissolve and loosen deposits that are present in the tank and fuel system. Phase separation may occur, resulting in an approximately 50/50 ethanol and water layer at the bottom of the fuel tank. Never use E 15. I use only no ethanol in classics, .and pay the few bucksâŚin a year of driving adds up to the cost of a few pizza.
Nick
