I have converted from an automatic to a manual transmission and in the
process also opted for a Fidanza aluminium flywheel. Going through the
parts manual I discovered that the auto flexplate with spacer ring
have different bolts than the bolts for the flywheel. 2 different
part numbers. Can anyone tell me the difference ?
Yes, the flywheel bolts are longer, because the flywheel is thicker.
But what is the correct length.?
I’m sure you could just measure the thickness difference between flywheel
and flexplate + spacer ring.
The
Fidanza flywheel is thicker than the original steel flywheel, so
should I not go for bolts that take that into account ?
How much thicker? And where do you suppose you’d find exactly the right
length bolts? If it’s no more than 1/8" thicker, I’d probably just use the OEM
flywheel bolts. If it’s a BUNCH thicker, yeah, you’ll need to find suitable bolts
– and if the heads aren’t the right shape, you might need to find different lock
tabs, too.
Can I simply
measure the crankshaft flange, the flywheel thickness and maybe the
lock tab ring and ad up the three to get the correct length ?
Both the flexplate and the flywheel use the same lock tabs, so those won’t
make a difference. But yeah, adding up the thickness differences is the way
you should go.
Are they
Grade 8 bolts or something completely different ?
They LOOK more special than that, but I don’t see any good reason regular
Grade 8 wouldn’t work. You might look around at Chevy flywheel bolts or the
like and see if any just happen to be the right size. When you’re doing all
this, lay your clutch disk on the flywheel and check out the clearance
between the center hub of the clutch disk and the heads of the bolts,
remembering that the clutch disk gets compressed a bit in actual operation.
You haven’t mentioned the two drive pins. The flywheel uses longer ones
than the flexplate, and for the same reasons you might need longer ones yet
for your thicker flywheel. If so, I think you’re in for having them custom
made.
Frankly, I’m a bit surprised that Fidanze doesn’t make their flywheels exactly
the same thickness there so you could use the OEM hardware. That, or
provide the needed hardware with their flywheel.
– Kirbert
