I have just purchased a Bonnet Rear Rubber Seal BD4920/3 and it’s only 21cm long as per the photo. The one I’m replacing goes all the way around the channel at the back of the engine compartment in front of the bulkhead and is about 130cm long. Which is correct?
I just checked and mine extends about 8cm either side of the scuttle vent - about three times as long as your newby. Mine has been replaced at some stage. Paul
Mine is 21 inches long , same size as the old one I took off , I have had the car for 40 years , so think the old one was factory !
It’s there to stop the water getting on the Control box , so I guess a little over hang each side of the shield is ok !
Thank you both for the messages. It’s odd that it wouldn’t go the full length of the bulkhead? Just trying to get my head around the thinking behind the seal?
As Ian has stated - just to protect the area over the solenoid. I have experimented with full seal and also to include all sides and soundproofing was excellent, but unless I cut the side triangle vents out, little place for heat to go.
