I put my rebuilt brake mc back on my car. I opened the front outlet pressure fitting that goes down to the servo thinking that it would fill the mc by gravity once I filled the rear brake reservoir thats connected to the mc via the banjo fitting. However, the mc didn’t fill up. I eventually shoved the rubber hose from the mighty vac into the front fitting on the mc (see pic).
I could easily pull fluid from the reservoir through the mc by doing this. However, I still have no brakes. Also, after removing the rubber hose, fluid still wouldn’t flow through the mc by gravity(see pic).
Wouldn’t the master cylinder be primed by pulling fluid through it? The only other odd thing is that when I loosened the other end of the hard line (see pic yellow circle)
at the slave cylinder end, I expected to see brake fluid drain out of the line since I hadn’t removed it to replace the mc. Shouldn’t that hard line have been filled with brake fluid?
I had the entire brake system: mc, slave, and booster rebuilt in 2014 by white post and got it all working afterwards so I know I am capable of bleeding the brakes, but I can’t seem to remember what I did. Thanks!
My experience is that even if you could pull fluid through it, you would still have air to bleed out of the system that is between the outlet pipe and the servo. This means that you would need to have all pipes connected and pump the pedal and bleed the circuit by pushing fluid through to the front caliper circuit (I assume you have a later car where the master cylinder is direct to the front circuit.)
If do you want to pull fluid through the master cylinder, I suggest you pump up some vacuum with your setup, then pump the brake pedal. But you will still need to bleed the system at a front wheel when it is all connected up
Okay, thanks, I’ll try bleeding at the calipers. I still can’t figure out why the steel outlet pipe going from mc to the servo was empty when I disconnected it last night since I hadn’t disconnected it to r&r the mc. Seems like it should have been full of fluid.
Pressure bleed by applying pressure to the reservoirs as discussed elsewhere on this forum. You might need to run the engine so you have vacuum to stroke the servo.
I’ve been trying to rig some kind of lid with a air nipple to pressurize the reservoirs. I assume that I wouldn’t want to put too much pressure on them and crack them.
The one advantage to the inner tube method is that with the Schrader valve, pressure could be maintained for an extended time vs my gas cap method not having any kind of valve as is.
Geo, when you are using the inner tube to pressurize the brake reservoir, what location are you bleeding the brakes at: master cylinder front fitting, brake servo fittings, wheel calipers, or all of the above?
I can now bleed fluid at all 4 wheels with and without engine running, all 4 fittings on the slave cylinder: input lines from front of mc, and front brake reservoir, and 2 output fittings going to front/ rear circuits, but I still have very little pedal.
Last month before I took the mc off as a result of my brakes locking up (presumably as a result of the secondary mc piston sticking), my pedal was excellent. Thanks!
Then, I pressurized the rear brake reservoir to get any air out of the mc. I then bled out of both output ports on the slave cylinder. Then, I bled all 4 calipers. Interestingly, I never did get even one air bubble out of any of the calipers despite bleeding each one 4 or 5 times. The only place I ever got any noticeable air out of was the mc output port. In the end, I finally got a good pedal. The 5 gal gas cap made it very quick and easy to pressurize either reservoir bottle.
I bled mine with these after replacing the MC, and servo. No pumping needed. Just remove the reservoirs and connect this 60ml syringe to the rubber hose and push it the fluid. Fronts and rears are on separate hydraulic circuits. Just loosen each bleeder individually and pump until you have no air coming out, or in my case until clean fluid was coming out. I started with the rears then did the fronts. In the end I think I bled about a liter through the entire system.
Wanted to share my brake bleeding set up. I have this small Gast air compressor / vacuum generator. I purchased a couple of screw on lids that someone else here posted, some hose , fittings and a quick connect.
Works good but I had to choke it down a bit as even with the pressure control knob lowered all the way the pressure was a little too high ( in my opinion).
I guess I could connect the vacuum side to the hose going to the vacuum reservoir to follow some recommendations about having the engine running while bleeding the brakes.
I had to break the connection once, for each reservoir, to add some fluid during the bleeding process.
I’ll be bleeding my brakes at some point after I’ve replaced all the calipers and the master. On airplanes, the mechanics simply bleed the brakes from the bottom up by pumping clean fluid, 5606, up from the calipers to the masters. Once fluid reaches the master reservoir, it’s finished.
Is the brake system on the jags, or cars in general, too complicated for that to work? Small airplane brakes are very basic.
It seems like a lot of cars are modified with the remote bleeders. I’ll be dropping the diff so I’m thinking it would be wise to add those now.
No, it works fine. I’ve never “bench bled” a cylinder, nor do I use power bleeders. The system may be complicated, but it works just like a real braking system. Clutch, same deal.
Mike gets better results than I do - I seem to find that I can easily bleed one end of the E-Type (the rear) and then have to get creative to get a bleed going on the other end. My ‘go to’ for that is a homemade pressure bleeder. Many posts on this if you find you have an issue.
I do not bench bleed per se but sometimes crack open the supply line to the servo to assure there is mostly fluid rather than mostly air in there.
I have the remote bleeders on the rear. I like them because they end at the bottom rear of the IRS cage, letting me bleed the rears by just sliding in under the boot. Handy, but hardly a necessity.
