Brake conversion, front disk mki
Im looking conversion kit brakes for MKI 1959
First complete your registration, so people now where you are.
Try SNGBarratt, they have all the parts, and brake conversion sets.
Do you have Drum brakes now?
In that case you need a remote vacuum brake booster ( only for the front in case of drums at the rear)
I would not change the rear.
If you change the rear you need a complete set from a MK2, including the hand brake mechanism.
Not suggesting you do this but many years ago I had a 2.4 Mk 1 and a scrap XJ6. I installed the XJ front hubs complete with calipers and upright in the Mk 1. This setup had too much negative camber so I extended the upper control arms. Also replaced the Mk 1 booster with a larger S-type one. The setup worked well, the brakes were feather light.
I dont know if this will be useful to you, but I suspect it will
[Saloon-lovers] MKVII Disc Brake Conversion - Saloons - Jag-lovers Forums
thank you for your help
my regards
thank you so much for your help
My regards
