Have a little brake fluid leak at the junction of the pressure differential
warning actuator.
I would like to know what the best way to approach is. ?
I could look for a new actuator, which is hard to get?
To replace the “O” ring between the electric unit and unit?
actually, I’ve never heard about any good metal tube connection that happened to let go all at once. Rubber tubes will fail over time and anything that does mechanical work like a brake cylinder may develop internal leaks. Metal connections usually only break due to vibrations or undue stress.
Looked at the brake cylinder today, it has an outside small “O” ring
going to the electric wires, which tells me that “O” ring is broken
but it has no function on the wire connection.
Walter
