My sensor was sticking on regardless of fluid level. Flickered every now and then but mostly on. Since I have fixed it and couldn’t find a lot on the web on it I thought I’d share some pictures and my experience.
First the system is connected to both the hand brake and fluid reservoir. If you disconnect the fluid reservoir the hand brake circuit still works - you can confirm it is the fluid reservoir that is at fault.
The red cap is held with two rivets like this. I tried to cut a slit in the top to screw them out - no success. Couldn’t get deep enough without chewing up the cap. I used a ‘Dremel’ tool with small cutting disc
As it turns out the red cap is made of a soft plastic and the heat from the attempt to cut the slit melted the section that the rivet clamped to… pulled right off while still soft
Next I needed to get the sleeve off that the float moves up and down in. It was held in place with a small divot punched into the side that matches a divot in the plastic underneath. See here where I had drilled this out and then reassembled later, lined up with the little divot in the plastic and given a gentle tap with a punch to secure.
The reason the sensor wasn’t working was the cork float had become saturated and was no longer floating. It is held on the metal rod with small brass washer. The end of the rod is flattened to stop the washer coming off the end. I simply ground off the extra width to allow the washer to come off followed by the cork.
I replaced with a wine bottle cork. I had a plastic one I would have preferred but old fashioned cork is what I had.
I cleaned up the contacts at the top and reassembled
You can see that the top of the aluminum cap is split in a couple of places. This is a weak spot and probably inevitable given the tendency to want the cap real tight. When I reassembled I placed a rubber washer between the aluminum an red plastic cap. This supports the aluminum underneath. I used stainless steel machine screws in place of the original rivets. I needed to not over tighten them so that the red cap could still rotate independently of the aluminum cap underneath so I could line up the wires later.
It works
Dave
