Ok we went for a spin in the Jag , found a nice pub about 10 miles from home , about 5 miles on the way back , a faint screech started , now and again , like the sound of a fan belt slipping , or a water pump on its way out !
So kept my eyes on the temp till we got home , all was well , no water from the pump , fan belt was ok .
So thought about the brakes , so feeling all 4 wheel , they was all very hot , too hot I think !
I did notice that when I did use the brakes , the servo would hang on for a few seconds after I let go of the brake pedal , but thought nothing of it , maybe the servo is hanging on a little I thought .
So yesterday I disconnected the servo , and took the car out for a spin , well I know the servo is working , because of the amount of force needed to stop the car ,
After around 15 miles I got back home , and felt the hubs , the 2 back ones where hot as the day before , but the 2 fronts where a lot cooler , normal I would say !
Had a talk to my dad and he said it should be the other way around , as the front brakes do more work , he asked me about a brake balancer , on his SP250 there is a device that splits the pressure , more to the front then back , well as far as I know the MK2 , has not got one .
So , what do you think ?
Have I got 2 problems , the servo , as when it was disconnected the hubs at the front are normal temperature .
The brakes must be holding on , but the car rolls fine , slight hills I have to use the brakes , and car rolls fine , I can push it with no problems , as I roll it up to the garage door , so it can’t be opened ,
In the manual it says master cylinder by-pass port chocked , for brakes holding on
Am thinking I should get a new servo , one of them 4-25-1 jobs , and maybe a master cylinder while I am at it both are standard from 1968 , both have been rebuilt in the past thou !
Brake system is , air tank removed from the servo line , copper brake pipes , 3 new rubber brake hoses , pistons in callipers rebuilt around 3 years ago , all new brake pads , silicone brake fluid.
Anyone else had the same kind of problem ?
