Hi
Would anyone know what size the lock washer is on the steering arm of a Burman PAS box?
Item 40 on the diagram below, and is it the same on an Adwest?
I can seem to find one from the usual suppliers?
Regards
Hi
Regards
Ian
Yes, I saw 8210 on the usual websites too, but none available. I also found on the Adwest box 11019 or P4101, not sure if same size, but none available.
I guess I am going to have to take it off and measure it and try and find one that way. It has been used to lock the nut, so looking a bit tired these days with all the bending over.
Regards
Worth asking the size !
good spotting…Dont even need to ask the size…the Landrover Defender etc use the Adwest Box, and it takes the same Pitman shaft seals as the Jags!..so it will be the same size
Any oversize (OD) washer will do, it just gets hammered over
Ian, thanks - very good spotting
I have ordered one and we will see!
Now back to the new front discs
