Is anyone aware of a list of all of the components that are cadmium plated on a 64 OTS?
This may help you.
All of the front suspension bits except the T bars, the brake calipers and pots, the bonnet spring hinges, fuel rail, and throttle linkage. I think virtually all of the fasteners were still black oxide. Black zinc is a cheap, easy substitute and lasts longer.
AJ:
Suggest you check out the JCNA published Series I E-Type Judge’s Guide - it has lots of relevant info on the subject. Here’s the link: https://www.jcna.com/sites/default/files/files/e-type1.pdf
