69 Coupe
I’m currently working on some final minor body issues re: my body-off restoration. When stripping the car, I noticed that the lower metal cover under the trans had been hacked open. That issue is the last of the body repairs that is needed. I recall reading a post some time ago that the “can opener” procedure is not that uncommon. I’m curious as to why this is/was done? Akthough it is approx 18" in length, it waould not have been wide enought to remove/access the drive shaft.
Also, what is acceptable repair for this type of damage? My initial thought was to cut out a nice rectangular section around the “hacking job” and weld in a new piece. I also thought of possibly cutting out a piece and then welding a substantial amount of nuts so I could bolt on the new cover section but since I am not an engineer, I’m not sure if that would be structurally sound, or not?
