Can we loosen the bolts attaching the battery of the MKV ” fully ” without a problem? Are there namely no nuts attached at the driver side for the bolts penetrating the metal wall behind the battery, between the driver side and the engine room ?
If like the MK2 then there is no problem taking out these long bolts. They are an inordinate amount of threads on them so you’ll be turning the bolt forever!
