BRG exterior, Suede Green interior, tan soft top
The utterly complete and thorough restoration included:
Suspension
• New front suspension rubber bushings
• New front & rear suspension rebound bumpers
• New GAZ front shocks
• New rear shock link arms
• New upper & lower ball joints
• New wheel bearings and seals
• New rear spring leather gaiters
• 4 New tires and tubes
• New chrome knockoffs
Brakes
• New brake wheel cylinders (front and rear)
• New brake dual master cylinder
• New brake stop light switch
• New brake lines
• New brake hoses
Fuel system & cooling
• New fuel tank sender
• New in-tank fuel filter
• New fuel pump
• Carburetors rebuilt
• Re-cored radiator
• Water pump rebuilt
• New thermo-controlled electric auxiliary cooling fan
Engine
• 6 new pistons, rings and pins (+030)
• New main and rod bearings (+010)
• New small end bushings
• New valve springs
• New tappet hold-down set (Inlet and exhaust)
• New timing chain, guide and tensioner
• New gaskets, seals and pilot bushing
• New starter & dynamo brushes
• New complete clutch: (drive plate, driven plate, release bearing)
• Resurfaced flywheel
• Harmonic damper rebuilt
• Re-porcelained exhaust manifolds
Interior, etc
• New cloth insulated wiring harnesses (as per original)
• New tri-bar headlamps
• New Lucas driving lights
• New tail lights
• New Original Specification Jaguar Interiors convertible soft top
• New OSJI interior kit with Wilton wool carpets & Connolly leather
• New weather-stripping throughout
• New Bell stainless steel exhaust system
• Extensive chrome re-plating
• New 12-volt battery (easily returned to twin 6-volt units if desired)
• New Baltic birch floor boards
• New Baltic birch boot boards
• New bumpers (front & rear)
• New windscreen glass & rubber
• New screen washer unit
• Clock rebuilt (it actually works)
This car has a clear Ohio title and comes with the Jaguar Heritage Trust Certificate, tool roll, side curtains in original storage bag and a DVD of the complete photo record…over 300 pictures before, during and after restoration as well as scans of receipts.
Description:
Asking price (if selling):
Contact information:
