I have been bothered with a regular sputter at idle and have noticed evidence of rich mixture so I am digging into tuning the carbs. Note: I have converted my '68 to triple SU’s. Also, I am a real noob with carbs. Removing the center carb housing and piston revealed this:
I don’t understand how this can be unless #21, the “jet bearing lock screw” has fallen? Has that ever happened? Any guidance on how to move forward is greatly appreciated.
Thanks for the quick reply Dennis. Yes, I guess it’s got to come out. The picture is hard to make out but both the jet (#1) and the jet bearing (#20) have dropped. Probably closer to 0.200" than 0.125"! Am I seeing the schematic correctly? Does the jet bearing have a collar that the jet bearing lock screw (#21) bears against to keep it from dropping? If so, has anyone ever had the lock screw back out?
You will need to take the carburetor apart and follow the jet centering procedure in the manual. That should fix it unless something is stripped out. Probably just loose.
Sooo… the jet bearing lock screw backed out. The threads appear to be OK so I’ll follow the centering procedure, re-install and hit the road!
I won’t bore you all with the back story but suffice it to say that I didn’t properly follow the setup of the carb after getting it back from having shaft bushes replaced and that most likely allowed the screw to slowly back down.
If the nut hasn’t loosened, it’s also possible the carbs were rebuilt with bad parts. Mine were rebuilt by me 20 years ago and were very hard to tune properly. It wasn’t until some years later I found the reason why. A lot of badly machined brass parts had crept into the supply chain and were being sold even by specialists. The dimensions were measurably off and I installed them without knowing better.
