I think given the design, you need to close everything, doors, trunk, windows, roof and tank … but … but it only closes the windows! Out of curiosity, I removed the passenger side knee cover and pulled out the central locking module. This despite the numerous cables it runs it has only two connected, all the others have been cut by some old psychopathic owner! In the control I found that the speed control cable was also cut !! Now it will be complicated to figure out and I am considering whether to bring my lover from the electrician, as long as this is able to fix this mess of cut wires …
In my 89 xj 40 that is the panic button! It closes all winbows, sunroof and locks all doors. Mine works at this time, if you need photos of anything under the dash let me know as I have just removed the dashboard and have access to most items under neeth.
wonderful!! do you take a picture of the plug that goes into the central locking module and what goes into the speed control module? and maybe some photos here and there to understand how the kilometers of cables that are below are arranged …
Also having been a ‘40 owner I can attest to the intricacies of the central locking, BTW if you are not careful this could be what you become however with the help of this forum hopefully you won’t be reduced to that state.
David…if you can post that photos this monday the car goes to check all this Wired and it’s better if I show to electronic mechanic all… photos and some electronic scheme. Where Can I find It?
If you can find a Haynes Manual there are Electrical wiring diagrams in there that will show what the wires should be. I am away from home at present but also seem to have mislaid my manual so unable to help.
