Changing engine and trans. oils
(spurs) #1
when changing the engine and trans. oils i usually have the front of the car up on a set of ramps for ease of getting at. is this ok or should i have the rear on axle stands to keep the car level.
(Andy) #2
It’s fine for the gearbox, as the drain is at the rear I think.
You would get more dirty oil out the engine if it was level
(Gordon) #3
I like to keep it level so trans oil doesn’t run out the rear of pan when loosening and engine oil drains out completely.:blush:
(spurs) #4
about how much oil will come out of the gearbox?
(Gordon) #5
Only what’s sitting in oil pan, about 3 /4 litres,if you keep it level when removing, minimal spillage,lay out newspaper to catch what does spill.:+1::blush:
(Andy) #6
The supercharged merc gearbox has a drain plug. Thought ZF would too.
You can get more out the gearbox in other ways if you wish.
Is it a weekend Car?
(spurs) #7
yes mainly weekends but usually longish trips, 200-300 klms.
(Andy) #8
I drained the gearbox from the drain plug.
I then Disconnected the gearbox cooler pipe at the front.
Left it for a week for gravity to drain oil down and got another 2 litres out the bottom
(spurs) #9
sounds the way to go, thanks.
(Rodney ) #10
They used a GM box on X300 XJR’s, the drain plug is on the left side and you can expect less than 4 litres to drain out.
(Andy) #11
HUmm
That is the problem having a forum coving 3 or more models years!
Each XJR having a different manufacture for the gearbox!
Do we know what year/country the OP is in?
(motorcarman) #12
AndyKAndy
12h
HUmm
I agree!!
The cars in this section can have ZF4HP24, ZF5HP24, MERC W5A580, ZF6HP26, GM4L80E.
Sorry to say, I will not participate in mystery car discussions.
bob
(spurs) #13
mine is a 1995 model in australia.
