Hi all
I’m getting to the short end of my to-do list to solve my “almost overheating” problem. No boil over, but into the bottom of the red zone, and dieseling at shut down.
So far I’ve:
Used a infrared tester to confirm temp of radiator at top is >200° Outlet is about 185° ( “calibrated” IR tester on boiling water)
Checked the functionality of the otter switch
Replaced all coolant hoses and continue use of metal center portion of bottom hose.
Replaced the OEM fan blades with Flex-a-lite blades( using factory round motors). Someone on the list said that combination had better flow than even the CoolCat fans.
Confirmed fan rotation rotation is correct, and pulling air through radiator.
Fresh premixed 50/50 coolant
Added Red Line Water Wetter
Checked plugs and no sign of running lean
Using a piston stop, dual stop method, confirmed timing marks on damper and set timing to 10° BTDC
The only things I can think of are radiator and water pump. No signs of failure of the wp and according to the PO the radiator was redone about 2010 and it looks fresh:…and it hadn’t seen many miles.
I’m tempted to pull the radiator and bring it to a shop, as that’s all I can think of for a next step.
Possibly my distributor isn’t 41060 distributor isn’t advancing??
I’m at a loss… one thing is my fans never shut down. Once they reach temp and engage, they never get the coolant temp down to stop running. So I’m thinking that it’s a problem with the cooling, vs a problem with creating too much heat. (Running lean, timing off)
Thoughts on next step? Pull the radiator or??
