Original burl walnut looked bad and cracked. This was not stained, only clear coat applied.
WOW!!!
Color seems to match the switchpack???
bob
Hi Bob.
Itβs a pretty good match apart from the dark spot on the bottom of the veneer around the switches. I also replaced the veneer on both side vents, used the same cherry stuff and just clear coated it.
