Oil pump/pickup and water pump would be worth $125 to me if we could avoid postage by doing pick up. Which side of ATL are you? Are you going to Columbia for the JCNA meeting in Aug?
Peter, sorry, just realized that I never replied to this…Sure I’ll take $125 for the oil pump &pickup and water pump if you still need them…I will not be going up to Columbia in August, but will be going up to the Carolina Concurs at Little Switzerland again (met you there several years ago). JS
Sorry I have not replied sooner to your message about my query regarding the carbs. I am not very computer literate and I struggle to navigate the Jag lovers web topics.
The secondary butterfly valve is inside the manifold at the front and your first picture shows the axle coming out of the manifold which this valve is attached to. Your second picture confuses me since if this is a picture for the rear of the manifold I don’t know what the shaft coming out of the manifold is. I will check the manifold on my car.
The reason I am interested in your set up is because my car has been modified by a previous owner to use two HS8 SU carbs from a 1952 XK120C and the secondary butterfly valve has been removed . I considering returning the car to standard with two 175 Stromberg carbs as I have experience with these carbs and I think they are equally as good as the SUs
