On both sides the windows are the same, just the rail on the underside is the other way around.
The right side will also give you a pattern for the other side.
Try any windscreen supplier. They are able to cut window glass to a pattern you provide. They provide a lot of special cut pieces of flat safety glass for vans, boats, etc.
If you provide them with the good window from the other side (complete with the bottom rail) they should be able to cut you a copy and grind the edges and radius the corners. If they are fussy they may want a clear pattern, eg a plywood or thick cardboard. You can make this easily from your good one and you don’t need to remove the bottom rail as there is enough glass clear at each end to match the size.
Just a comment - the new glass will be so crystal clear that it might ‘outshine’ the other side. If the other side is chipped, scratched or etched, you might consider cutting two and replacing it too. Always keep any patterns or templates you make, you never know when you or a colleague could use it in the future.
AFAIK, all Mk2 glass is the same model for model ( ie 2.4, 3.4 3.8 ) and I believe the same is true for S Type and 420, except for the rear screen. Doors are the same apart from the internal mechanism.
