I am considering using the 5/8 master cylinder from the XK for my E-type that currently has a 3/4. The thought is to reduce pedal effort using the smaller cylinder while still having enough pedal travel.
I am unable to get the dimensions on the cylinder from XKs unlimited and am hoping someone may have them or is able to measure them. Specifically I need the distance, center to center of the mounting holes in the flange, the diameter of the rubber dust cover over the pedal rod/cylinder and the length of the pedal rod/clevis from the flange to the end of the clevis or center of hole in clevis.
From my XK150, they are:
holes are 2.25 in center to center
Rubber cap is 1.35 od, installed
Clevis pin center is 6 5/8 in from flange face, fully extended, with about 1/2 in of adjustment either way
Thank you very much, just what I needed. Only other issue is the fork disk retainer diameter which based on your rubber cap measurement should be quite close.
