Does anybody have an explanation/cure for this:
Mk2 Manual. Driving in slow city traffic on warm day. After 30 minutes drive clutch started to took on very rapidly but gears went on without problem. Then after half of mile, clutch did not release anymore, I could not get gears on. Car towed home. Next day I jacked car up and looked slave cylinder, which I suspected. Little dampness under shaft rubber but no leaks, not even when pedal pressed. Shaft moved about 1". Rubber hose ok, no leaks even when pedal pressed. Container 95% full. Then I tried clutch/gears and everything worked fine! Took a short test drive, no problems.
Could it be that old (guilty, I admit) fluid boiled in hot environment? I changed it now.
Or some other explanation/reason?
Köpi
old, hard master cylinder seal bypassing. Mine did that , gradually worse.
Doug
Wouldn’t that leak into the footwell? I didn’t notice any leaks.
Köpi
Not necessarily: that would be my first area to rebuild.
If the fluid I’d really old then it could have boiled, never heard of it but there’s always a first time.
You could try flushing out the system but that will likely end up with the seals expiring.
Worth a shot, and easy enough to do.
I already changed (or is the correct term flushed) fluid like I wrote in my opening.
Today I took car for a 40min city test drive, no problems, feels just like before.
But I’ll order new master and slave cylinders (or seal sets if available), it’s time to rebuild those.
Thanks for the comments.
Köpi
I can’t see boiling on a clutch slave. Brake calipers have significant heat input. Clutch slave not so much
I agree but I missed the part where the OP had changed the fluid and taken a drive and the problem didn’t arise again, maybe the circumstances didn’t quite reach the level of the drive where the problem occurred.
Maybe change the hose, although I don’t think that’s the sole cause. Make sure that a slave return spring wasn’t added if it’s a model that does not require it. The later e-type system is that way (no spring) and there was recent discussion on this forum about a 420 with a similar problem to yours because of a spring added by mistake.
The hose looks fine, is dry and does not bulge nor leak when pedal pressed.
Car has earlier C21470 slave cylinder, which does require return spring and the spring has been there 60 years without problems
Only changes between malfunction and later test drive without problems was change of fluid and test drive was longer (40min instead on 30min, outside temp same within few degrees, drive speed/stops/clutch use similar).
Köpi
Then I think nothing to do but assume it was hot old fluid and drive it. If it recurs, I would rebuild or replace the cylinders and the hose.
I guess you guys were right: it was not boiling fluid but old seals.
After car was unused for a while, symptoms came back and again disappeared when I used car regularly.
Sounds like seals were drying and leaking when not used and swollen when used.
So I replaced the whole master cylinder (old one had some surface rust) and seals to slave cylinder and now it is back to normal.
Thanks for help.
Köpi
You might want to consider saving the old cylinder as it could be sleeved and reused with new seals at some point or available to someone else. Rust and pits in the bore can easily be overcome with sleeving and this is a very permanent fix.
Yes I will save it. And already got new seal kit. Just in case…
