My '89 Series III V12 has had its thermostat housing changed at some point for an earlier one.
This means there is an unused thermotime switch. I’d like to replace it with a temperature sender linked to a separate monitoring computer I’m building, but despite extensive searching I can’t find out what the thread is and hence get an appropriate sensor!
I’d appreciate it if anyone knew, or if someone has a proper thread gauge they could measure it with that would be really helpful!
take it out, take it to a big box store like Lowes or Home Depot, or an Ace Hardware. They have a thread gauge usually mounted next to their nuts and bolts section. After you think you found a match, then get a nut that size and see if it will thread onto the threaded portion of the switch easily - - at least thread the entire nut onto the threaded section. To verify a good fit . Then you can have confidence that you have determined the correct threading used on the switch, and ergo the hole you want to screw into
Kirbert
3
If nothing seems to match, the thread is probably BSP or Whitworth!
I’m almost certain it’s going to be something a smaller diameter BSP… Seems to be common to a Ferrari 308 as well so might try there, can find lots of descriptions but no detail on what the actual thread is!
