Please help. After fitting the warning lights with new LED bulds,
most of the lights stop working. The temprature, oil pressure, low
coolant, brake, fuel, parking brake and ABS warning lights stop
working the minute I replace the last bulb. I have checked all the
fuses and they seem fine. When I turn the four way on, you can
barely see the 4 way indicator sign buld glow. But the blub glows
brighter when I turn only left or right indicator on. The only
warning light that comes on when I turn the ignition switch is the
battery and the seat belt warning lights. The instrument panel
dimmer is not working properly. The panel lights goes in and out
when I try to adjust the panel light with the dimmer
Thanks…–
the oppressed is freed
new windsor new york, United States
In reply to a message from gus de man sent Mon 8 Nov 2010:
You’ve posted this to the wrong forum section. Dependent on
what model of Jaguar you have pick a forum that deals with
that car and you will get much better response. Always
quote the year and model of your car as well in your post.–
John Quilter 1965 3.8S, 1951 MGTD, 1960 Morris ,1990 XJ6
Eugene, Oregon, United States
