Where does these wires connect to?. I can’t locate them on the wiring diagram I have
Seems like green/white, Janson - which is (originally) between fuel relay and the fuel pump. Check at the fuel relay - or possibly look for another connector with the same wire colour?
Frank
xj6 85 Sov Europe (UK/NZ)
Green white?
Where do the wires originate? If you include a photo of the plug I can look.
Janson,
Clean off the wires and tell us what colors the wires are. What wiring diagram are you using?
Green with brown tracer and brown with black tracer
Again - where from? Green brown does several things iirc
Janson,
The Green-Brown (GN) wire is for the A/C compressor clutch and the Brown-Black (NB) wire goes to the back of the alternator.
This information is easily found in the Series III Service Manual and the S57 Electrical Guide. I am not sure what document you are using to sort out your wiring, but if you don’t have these documents you will be wasting a lot of time unnecessarily while trying to figure out your wiring.
