i have a 94 that has a totally bad accumulator brake set uo is there any way to put vacuum brakes on it
I’m not aware that anyone on this forum has converted a Teves equiped '94 (or earlier) XJ40 to vacuum brake boost (or needed to).
What is wrong with the Teves system on your car? Is it simply a failed accumulator sphere, a failed Teves pump or what?
this car had been sitting for several years runs and drives good but the pump and motor for pump and both locked up .
David,
Have you tested the pump / accumulator / combined pressure warning switch off the car? I think I would be inclined to search for replacements at a breaker’s yard or in the case of the accumulator buy a new AC Delco (Buick Reatta) #25528382 to restore the Teves system to full working order rather than convert to vacuum assist just for brake boost.
and loose the ABS.
