you’ll still have the capacitors (condensers) slowly failing, and in need for a replacement after 20 or 30 years, and replacing those needs to open the controller
if you have the controller open, the fix is easy, just follow John_John1 suggestions in the same thread you posted above
the change of value for the resistor prevents the IC to blow again in the future
