I got my ECU’s back from Roger, aj6engineering. He found no faults it either one. Which I am kinda glad but would have loved for it to be my problem. After over 7 months, I put the 6cu back in, it started right up after the fuel circulated. I drove it around a bit, nice, smooth thinking “cool”! Then I gave it some gas, lots and it immediately bogged down and backfired through the exhaust a few times. Not a steady backfiring but a few and around 4k rpms where the engine would not rev past!
I have replaced practically everything fuel or ignition related. Tank, pump, regulators, had injectors cleaned, new stuff in the dist, wires, plugs, ignition module. I have a vacuum switch and a manual switch that works together to richen the fuel. The throttle switch reads like its supposed to.
So, the one thing that is about 4 years old is the ignition coil. Really not old for a coil but its about the last thing I can think of. I forget the ohm reading I need for a single coil so was going to ask if there are any preferable ones that most have had good service with. Any suggestions?
It revs up nicely to around 4k then It just bogs, the occasional backfire, almost like a rev limiter but I am pretty sure these did not come with that feature.
that’s the one I bought, and have had zero issues.
I originally bought a PerTronix FlameThrower. Most people here on the forum had good results, but I must have got a bad one, as it ran terrible with it.
If you leave the tranny in park, can you rev past 4k under no load ?
Not quite the same as 4k under load, because under load much less vacuum.
Does it make a difference when driving if you slowly accelerate to 4k as opposed to planting your foot ?
That gives a clue.
I would check that dizzy again, an outside possibility the rotor has a gap to the terminal posts at 4k and you are not firing the plugs. A new coil might help too.
Changed my two oil drum coils for one rapid firing French made solid state coil. Had all sorts of problems under load. The supplier said it was common for these to fail. Sent me a couple of oil drums to replace it and all’s good. That was three years ago.
Well, you guys were right. It was the coil. Broke down at around 4k on my car in park. After putting a new one in it drives perfect! Power, idles without a miss, starts right up. Nice to finally be driving it again. It was an Accel coil, round, oil filled.
I looked for the DAC 6093 and found some but Jagbits was the only Jaguar parts store I could find one. $99.00. Not sure if I should go with the DAC 6093 now but there were no numbers as far as resistance on the Accel coil I bought. I don’t know if it will break down the spark as I drive it or if it would have not worked from the begining.
I noticed some of the dry coils, the 6093, had a 4 prong plug on it. Others had the spade plug ins. XKs unlimited showed the picture of one but said discontinued.
So, now that I know, any advice as to whether I should get the offered DAC 6093 or stay with the Accel oil filled coil?
If the Accel coil works no reason to change it unless somebody on this list has suffered failures with them.
Oil filled coils still work. Nowadays solid epoxy insulation is probably more common in coils. That might not be because it is a better insulator or have better thermal conductivity, it could be related to environmental concerns. I guess making an oil filled coil on plug unit would be tricky.
Thanks! That is a very clean engine bay. That is a good idea about the mounting for the coil too. Did you remount the ignition module too?
Russ
Kirbert
12
No, it’s because modern electronic ignitions control the current through the coil so it doesn’t need so much cooling.
Kirbert
13
The HEI ignition system calls for an ignition coil with 0.6 ohm primary resistance. When introduced, such things were difficult to come by, so Jaguar resorted to two 1.2 ohm coils with the primaries wired in parallel. With the secondary capped off on one, its energy is diverted back to the primary coil of the other, so the energy of both coils is applied to the secondary of the main coil. Later, 0.6 ohm coils became more common, so Jaguar introduced its DAC 6093. It doesn’t work a whit better, it’s just simpler and lighter. And you don’t have to use Jaguar’s version; you can use any coil with a 0.6 ohm primary resistance.
Coils have less heat dissipation for sure.
I doubt that alone explains why solid epoxy has been adopted.
Electric supply requires large power transformers which need oil for insulation and cooling. It was found a number of years ago that the insulating oils degraded over time to produce PCBs which are carcinogenic. I would expect auto coils originally used the same oil, but they would have to use better oil nowadays which might be more expensive.
Epoxy has been improved over the years so it can be a cost effective alternative.
Epoxy insulation for transformers has become more popular in smaller electric supply transformers, a matter of cost, performance and avoiding health problems.
The same situation will apply to automotive coils.
Well, I did put a new Accel coil on the car and it runs great. I just moved the mount to where Ronbros has his. The coil still heats up but at least it isn’t in the middle of the valley of the engine. Thanks for all the help, advice and technical knowledge. Never stop learning.
