I’m restoring an XK140SE with overdrive and found original trico PS-4A switches to replace the current one.
I want to come as close to original as i can. So i searches al sorts of books and documentation to find: on what side the switch should flip if the overdrive is turned on. On the car there is a metal circle that says overdrive in/out.
Does the overdrive switch toggle horizontally or vertically? I don’t believe I have ever seen a toggle switch on an English car that wasn’t mounted to work vertically, but what do I know?
Its a long time since I drove my ‘S’ but I seem to recall it was positioned so that I could just flick the switch sideways to operate rather than up/down without moving my hand from the wheel. Also that tends to go with the legend on the bezel.
I had better clarify that this is on a car that I converted from the DG box about 28 years ago, on checking both the ‘S’ and MK11 drivers manual I note that the O/d is operated from a stalk on the steering column so take my thoughts however you wish
