Greetings All,
Will get out to shop for pictures tomorrow. Work drained me and the 95F heat didn’t make me anymore ambitious after work.
I understand that they are using the flange to seal rather than the the “web” of cast iron in between the existing liners.
Not sure if longer cracks COULD be addressed. They would likely exist between the cylinder liners and I don’t see how there would be access?
I’ve had a couple of liners removed. They were machined out. It was deemed safer because of fear of damaging the thin material between. It’s also a good idea to work one cylinder at a time as you risk damaging that area?
With regards to the cracks, if you have sealed the combustion areas from coolant ingress, the cracks are irrelevant at that point, aren’t they? You have a crack, but the coolant isn’t going anywhere it shouldn’t.
Here’s one to cogitate on…
Jaguar used the same basic block for almost 45 years, obviously, with displacement changes, all the time that cylinder spacing was increasing to stretch the limits of what would fit between the bearing journals.
The space is not equal distant between all cylinders.
Compound this with the fact that the head’s combustion chambers do not center perfectly over each cylinder due and the sealing area is diminished even more because of the mismatch.
Roger Bywater/AJ6 Engineering, has written much about the XK engine having been employed by Jaguar during the XK engine production. It’s worth Googling and checking out his site. Read all six pages, especially the last page on uncoupling the block harmonics to keep from amplifying chassis resonance.
He recounts that many of the cooling issue ps manifested themselves in the last iteration of the XK in the 4.2. The wetliner construction being the main culprit as the inconsistent masses of metal that surrounded the liners effected the expansion rates in an uneven manner.
Since I’m most likely going to get out to the shop tomorrow, barring feeling old, any specific shots you looking for? Let me know before lunch time tomorrow.
The general plan…I believe I still have a 3.8, MKIX block with cracks between the bores, I’ll also grab a picture of the head and the mismatch if I can figure out a way to show it, along with a 3.4, 120 block so you can see the spacing difference, along with a fresh rebuild that still has the head off. Anything else, let me know.
As always…if anyone knows of a mid 30’s Standard Flathead Engine for sale…I’m looking for one for my SS1 Tourer.
