I have a basic question about the pressure achieved in a conventional cylinder compression test. I have a fair understanding of gas laws and pvt relationships but I must not understand how our engines work.
To start, I believe the theoretical pressure achieved in a SINGLE compression stroke in a 9/1 compression ratio engine with no leaks at sea level would be about 118 psi (if ignoring temperature effect). But I know that real tests achieve much higher pressure readings: 150 psi or more.
Why is that? One possibility could be that the pressure in the cylinder is higher than atmospheric when the piston starts the compression stroke. But I guess the opposite is the case. There must be a slight vacuum in the cylinder {ie. less than atmospheric pressure) in the cylinder at the bottom of the intake stroke when the valves close. And we know that there is a vacuum in the intake manifold. If so, compressing at 9/1 ratio should lead to a pressure lower that 118 psig.
Another guess is that the energy of compression is transferred to the gas as heat and the temperature rises.
That would result in pressures higher than 118. Is that the correct answer or am I missing something else?
Incidentally I have searched about a hundred posts on the subject of cylinder pressure going back over 10 years and have not found to answer to my question.
