[DaimLan] michelin tyres
(DstJohn) #1
My tyres are at least 15 years old. Michelin, 205 70R 15.
Same as E-Type later cars. I’m thinking of 16 inch wire. In
the pics they look awesome! The 195HR 15 just look too
narrow for my taste. Any comments would be welcome.–
DstJohn
(Bob Frisby) #2
In reply to a message from DstJohn sent Sat 5 Apr 2014:
May we assume that you’re talking about a Dart/SP250?–
Bob Frisby, S2 FHC
Boise ID, United States
(DstJohn) #3
In reply to a message from Bob Frisby sent Wed 9 Apr 2014:
Sorry, no, it’s a 250 V8–
DstJohn
(Roger Holmes, Microspot) #4
If you want to fit wider than standard tyres to a V8-250 you should bear in mind two things. Firstly the spare will not fit in the spare wheel well unless you cut it out and weld an extension strip in all around but more importantly, the clearance between tyre and wheel arch is marginal already, particularly when going over a bump at full lock. My own car has done this with standard radials and my brother had wide alloys on his and the car had extensions on the front wheel arches, and IIRC, no spats at the rear end. Even with the extensions he still had the tyres wearing themselves out scraping against the front wheel arches on full lock.
Roger Holmes,
