[DaimLan] RE: [Saloon-lovers] DV8 Stalling
I think the vacuum to your brake booster is leaking.
There is a metal box ahead of one of your front tires. It is probably rusty
and causing a slight leak. I believe others have said that metal box is not
needed and one can just hook the vacuum up directly…
Or you have a cracked hose.> -----Original Message-----
From: gary.westbury@kvaerner.com [mailto:gary.westbury@kvaerner.com]
Sent: Tuesday, December 07, 1999 5:45 AM
To: daimlan@jag-lovers.org; saloons@jag-lovers.org
Subject: [Saloon-lovers] DV8 Stalling.
Dear All
I have an annoying problem with my '66 Daimler V8.
When a brake to stop, as opposed to slowing down,
the revs of my engine fall away rapidly & more often
than not I stall. I currently have to flick the choke on in
order to keep revs up if I know I’m going to have to stop!
When warm the idle speed in N is about 900-1000 &
in D its about 500-600.
Any ideas grateful received.
Regards
Gary Westbury, UK
'66 DV8
