Dear “Listers”,
I have always believed that the best way to restore a
vehicle, if you have the space and are taking everything off, is to have
two chassis frames. Many of our vehicles have been stripped for spares
in the past and spare chassis frames are around for you to obtain. For
example, I have six Lanchester L.D.10. chassis frames in my garage.
Having two frames is by far the best method for a full
restoration, bacause everything is always either in place or in
progress. Even the bolts and spring washers do not get mixed up, lost or
put in the wrong way round. With a normal full strip down, everything
has to be stored in boxes, bags etc and refitted long after the item has
been removed. With this method, copious notes need to be made, the
memory fades, hardware and parts can get lost.
With a two-chassis restoration, each part is removed from one
chassis, restored or cleaned and fitted to the restored chassis, using
the same (or new) hardware, with full memory of the recent removal
process. Even the bolts will be put back the same way round. Strip down
and rebuild take place simultaneously, so depression is less likely to
set in and if you do give up, any prospective purchaser can see that
everything is assembled and in place on one or other of the chassis
frames. Even the body shell can usually be left in place whilst the old
chassis frame is being stripped. This reduces the risk of distortion.
I have just written this piece of advice to a car owner (not a
Lanchester owner) so I thought that I would share it with you. The
argumentitive ones amongst us can now tear it to pieces!
Regards, Adrian.
Adrian H. Hanwell.
AHANWEL1@FORD.COM.
[Commercial use of subscribers e-mail addresses prohibited.]==============================
