Tudor95
(Tudor95)
June 10, 2016, 12:37pm
1
As a new owner of a 1968 V8 250 I find it a Little low
geared for driving on our Autobahn’s.
Is it a big Job to Change the dif. ratio to something that
would give it a bit longer legs??
Best regards
Barry–
Tudor95
Herne, Germany
–Posted using Jag-lovers JagFORUM [forums.jag-lovers.org ]–
In reply to a message from Tudor95 sent Fri 10 Jun 2016:
Barry
It depends... It is only about 15 minutes more work than
rebuilding a diff without changing the ratio. OTOH it does mean
checking the pinion drop, so it means the same as rebuilding the
diff.
Doing this yourself, or taking it to a shop?
Andrew–
1968 3.8S
Zurich, Switzerland
Tudor95
(Tudor95)
July 3, 2016, 6:52pm
3
In reply to a message from JagWaugh sent Fri 10 Jun 2016:
Hi Andrew,
Thank you for the info.
I have never had a diff apart so although I do most things
myself, I think that I would give this to an expert. If I
can find one!
Barry–
Tudor95
Herne, Germany
In reply to a message from Tudor95 sent Sun 3 Jul 2016:
Barry,
It isn’t really a ‘‘Hexerei’’, but it does require a certain level
of attention.
Try and find a local Offroad club, and ask them who is good in
your area. Failing that a ZF Werkstatt.
Andrew–
can find one!
1968 3.8S
Zurich, Switzerland
