Hello, I’ve just been told that the ball-joints for the Mk 2 won’t fit the Daimler
What about the tyrods outer?
Where can I get reasonable calipers (front) $575.00 (2)
With thanks, David
I am 99% sure the ball joints are the same , top and bottom , on my MK2 the track rod ends are fixed to a bar , adjusted by the centre bar , very easy to adjust the tracking !
Hello, and thanks, The ones I;ve seen are not attached to a bar (ball jounts) ?, or are you referring to the track-rod ends {tyrods outer?}
Picture is of the track rod’s , ball joints hold the Stub Axle Carrier to the suspension .
Amsteer makes the side rods:
http://www.amsteer.co.uk/Jaguar%20Car%20Parts/AM492%20Jaguar%20MK2%20Outer%20Rod
Hi are the track rod ends on the fixed bar handed?
Yes. That’s how you get the adjustment.
Are these handed Ian?
The one’s in my picture are the same , not handed ,
Going by the parts book they are handed , but I think Jaguar changed them to the solid bar kind , like my picture , from ones you can adjust .
I have the later type , makes adjusting a lot easier , just have to turn the centre tube for toe in or out , moves both sides together 67 in the diagram ,
In parts book 66 is C 22679 LH , C22678 RH
