Anybody got any input on this…
'97 XJ300 4.0L AJ16.
Cranks but no start. fuel appears at the injection rail joint, and EasyStart doesn’t even produce a cough.
Not battery
Pretty sure now it’s not earth thought still checking.
diconnected crank position sensor shows 2.25 V across input connector (?) … is htis the problem …CKPS is Hall type ( dumb ) sensor …should be 0V on lead to it? could the stray 2.25V be coming from damaged ECU ? …presumably 2.25v is close to or even more that the actual expected output of CKPS and therefore probably the cause of the non start?
Like
