Delanair A/C hose routing
I am trying to revive a original Delanair A/C unit in my Mk2. When I bought the car 20 years ago it had the A/C components (three condensers up front and the evaporator in the trunk) but no hoses. The “chair” condenser sits in front of the radiator with a #8 flair exiting at the lower cover plate behind the grill and a #6 flair exiting to the driver side fender well. There second (belly) condenser is located behind the front bumper, parallel to the ground it has #8 flair fittings on either side. The third condenser is located in the left front fender well with two #8 flair fittings.
I assume they were connected in series. Does anyone know the order in which they are connected in series (i.e., belly, chair fender)? And does line with the #6 flair go to the compressor or to the evaporator?
On line search deals only with one or two condensors and not Mk2 specific.
Thanks in adance.
george
cincinnati ohio
65 Mk2
