I need a rear hatch latch which is attached to the rear door but have difficulty in finding ‘post an ad’ window. Any help will be greatly appreciated.
Eugene aka
old jag man
Eugene,
First this:
https://forums.jag-lovers.com/t/how-do-i-register-to-use-the-classified-ads/349045/3
Then this:
The DELETE function is outlined at the end of the CREATE section of this guide.
CREATING an Ad.
Step 1…Ad’s can be generated from either JL Home or Forum Home. The top menu is the same in either case. So, choose which location and proceed to the next step.
Step 2…Use the drop down menu on “Classified ads” and select “Place ad” and you will be taken to the following screen…
[image]
The box showing 1 2 3 4 is just a marker for where you are in the four step process.
Step 3…Use the drop do…
