Hello Gents,
Anyone know where does this electricial plug connect to?
Thanks!
Look for its mate within reach…?
Wire colors unclear - does the compressor actually engage with AC on?
Frank
xj6 85 Sov Europe (UK/NZ)
Air pump or not factory? Trace the wiring, but black/white black is unlikely to be wiring to standard. The plug is also nothing I’ve seen, so given the location it could be the air pump or an electric fan or…
Hello Gents,
The PO removed the air pump so probably goes to the air pump.
I will need to investigate further. The compressor does have a connector to it so definitely not for the compressor.
Thanks!
The diverter valve for the air injection pump did use a two wire connector on black and pink/white wires. So that does seems like a plausible answer. I also agree that the connector looks a little odd; a bit too modern for a Series III. But, it’s been a number of years since I really looked at one, so…?
DD
Thanks Doug, Frank and David!
