Has anyone been able to disconnect the front ABS harness link behind the wheel arch as I’m really struggling. There’s not much room and I can’t see it so have to use one hand to feel it. Someone has shown me you need to press the plastic tab at the end to release it, but I’m struggling to press that and pull it at the same time. Anyone please got any ideas?
Thought if there was the same connector somewhere easily access like the engine bay so I could see exactly how it works and practice releasing it with one hand that would be useful if anyone knows. What should be an easy job is turning out to be quite difficult.
Sometimes it helps to push the connector together as you press the release tab, you may not feel it move but it can release some tension that is holding the tab.
