Distributor vacuum regulator
Does the Petronix specify a vacuum regulator - and does it specify 17 deg advance…?
Also; do measure the vacuum at the dizzy hose in idle - if it shows manifold vacuum, 18" Hg, 17 deg advance, vac off, is too high. 17deg is a basic setting for ported vacuum advance. Lack of power during acceleration may be due to high advance…
A compression test will conclusively prove, or disprove, that the engine itself is not at fault. And a pro can easily check the fuel pressure…
Frank
xj6 85 Sov Europe (UK/NZ)
Thanks again for all of the help!
Sooooo…the stumbling doesn’t happen when I purposely cause a vacuum leak. If I pull the vacuum line off of the cruz control the motor stumbles and then works up to a higher idle and the stumbling under acceleration is gone.
I’m thinking it may be an issue back by the tanks. Fuel Chang over valve maybe?
The effect of disconnecting a vacuum connection depends on the size of the hose - the engine uses vast amounts of air even in idle, and a bit extra, air, a vacuum leak, makes little difference…
Idle will increase with hose size, some 30 - 50 rpms for a ‘normal’ vacuum hose - a large leak may interfere noticeably with fuelling as the leak bypasses the AFM. However, engine behaviour to an air leak may also depend on hose interconnections - and where the hose is disconnected, or the leak occur…
All vacuum operated devices are disabled by their vacuum hoses’ disconnections - so if the disconnections relates to the dist vacuum; the engine will react accordingly. In your case; if there is an interconnection between the cruise control, same or interconnected tap-off as the dist vacuum, it may have an effect…
Otherwise, a vacuum leak in itself will not be noticeable except for the idle increase - except for eventual interference with dist. To check eventual interference of the cruise hose disconnection - connect a vacuum gauge to the dist hose and observe eventual differences…?
As you are running the Pertronix dist I think the stumbling is related to that item. If the stumbling during acceleration is caused by ‘pinking’, the ign is too advanced by dist advance curve. The standard advance settings are given for the standard dist - and the Pertronix may require different settings and eventual vacuum connections…
If the engine otherwise performs at speed with the higher fuel consumption it’s difficult to see lack of fuel as a cause. However, a ‘regulated’ fuel pressure test will reveal lack of adequate fuel delivery…
Frank
As a complicating factor; the increased idle may in itself bring the engine rpms up past the stumbling point - though that is drawing a very log bow…
You are talking about two separate elements here…
Maybe, by disconnecting the cruise control vacuum line, you change the amount of vacuum at the distributor ?
As Frank asked, what does the distributor manual say ?, i.e. is the distributor seeing the vacuum values it’s designed for ?
Precisely, so maybe there lays the problem ? Maybe the Petronix doesn’t work like that ?
To check the Fuel change over scheme:
With engine running pinch the corresponding 12mm big hose before the change over valve (of the selected tank), the fuel pump should start whining. Check both sides.
For the return valves, open the fuel filler cap and listen if fuel returns to the correct tank.
How old is your Fuel Filter ?
Aristides
