After an overhaul of my IFS and steering components, I thought it wise to get a pro alignment shop to set toe-in up, (and cause they give you a printout of camber, castor and toe)…wrong!
I had to give them the specs myself, out of FSM, and INSIST they used the steering box centralisation keyway (which is whats its there for)…NOT the steering wheel (which I told them had been off its splines unknown times), they reset toe-in and give me a printout which shows everything is near enough to spec
(laser alignment equipment)
So my steering wheel is then ~3 splines off centre when maintaining straight ahead driving, even with steering box centralised and wheels dead ahead at ground, stopped
I decide to use the method described in FSM, using a 5metre channel section of aluminium as a straight edge…I also use calipers to check equal tie rod length, and a 600mm steel rule
it is immediately apparent that instead of toe-in, I have 10mm gap at rear of DS front tyre,meaning toe-out
and 23mm!! of gap on PS
the procedure is there should be a 16mm gap at front of REAR tyre, when straight edge touches front tyre both edges
ajust till I have this gap, but found tie-rods to be unequal length, so compromised a little for the moment, but it is MUCH better than before, steering wheel is now centralised, and slight to-in on each wheel
dont know how come the paid-for laser printout job was so badly out, but this is to recommend ye old skool ways to those who want to set up, or check the alignment
