I’ve been chasing mixture and timing trying to perfect my idle (4.2 S1 motor), fully warm it’s about 8-900 rpm in neutral, 6-700 rpm in drive. Steady but with an intermittent miss and the engine sort of vibrates, it’s not smooth. Plugs looks tan, about right, maybe slightly lean. I’ve tried richening with the screws but it doesn’t make that much of a difference and the engine never pings.
I’ve gone thru and tightened everything I can get a screwdriver or wrench on, but I’m not sure if I still have a vacuum leak. My 123Tune has a vacuum gauge on it that looks like the image below. At idle it reads 0. At speed it goes to -0.3 and holds there.
Is that normal or should I be seeing something else?
Thanks.
