I had trouble with the positive connection with the nut on it. Doesnt seem to line up perfectly. Was wondering if the wires are plugged in correctly. Thank you
No photo attached… and 20 characters
My Magic 8-Ball says Charlie has a 67 S1 and is asking about the alternator.
But yeah, a photo will help.
You are correct, working on car all day has scrambled my brain. 67 series 1
Mine is an S2 so not like yours, but I will comment that your wires seem to be straining to reach the connections. Any chance you can get a bit more slack in the harness?
Doing that might allow the big positive cable to move 90° outward.
I like a bit of extra length in that area:
Thanks, i freed up the harness a litte more. Should the posiitive wire be facing outward ibstead of verticle?
I see you have a clip around the harness and a ground strap in your photo . Do you know if that is correct?
I believe the strap was added by the dealer in Germany - there may have been a couple of things added by that dealer prior to delivery. No idea of the P-clip was also an addition.
