Not to brag, but… this is my (9:1) engine.
Pressures are in bar, you don’t want more than I think 10% difference between cylinders. MartinScherz has one cylinder that’s significantly low and the engine still runs fine.
Yours is not exactly good but it might well be your valve clearances? Either way work will need to be done. But then you have a good engine and know it!
Oh. The motometer tester is great. Did you test with engine hot or cold, did you open the throttle fully while cranking? That’s how we tested.
