Yes…exactly…I would have reduced the large piston diameter to reduce material costs of the piston and outer casing…you have to leave the slide in the Venturi the same…and pressed a predetermined mass of lead into the bottom of the dash pot chamber to achieve the weight required. No spring. Then gravity is your constant companion!!
