Hi folks, will be finally getting around to draining driver side tank (only one that doesn’t leak). Will be putting in line filter and replacing old canister filter as well. Is it ok to drain tank and leave empty for a while? Have other things to do with the car before I get her up and running and don’t want to replace the fuel to only let it get old again. Your help always appreciated.
depends a bit on what time frame you’re thinking of … I usually keep the tank filled up in hibernating cars and never had a problem with up to 5 months of sitting. For anything more there would be fuel preservatives for little money.
Leaving the tank empty for that kind of time would get me concerned. Even WD40 dissolves quickly and won’t protect metal surfaces for long. Maybe with a super dry environment … but I’d prefer to let the fuel do the protection, unless you see the ugly head of that long time restoration monster getting at you …
