Brandon,
Ethanol laced fuel has caused of many industry gasoline engine problems. Vehicle manufacturers have gone to great lengths to re-engineer engine components and related accessories to function with E10 or E85 fuel. IMHO Ethanol 10 is akin to the "Pump gas yourself and save $0.02 gallon (when first introduced) scam that came about in the 1970’s. That’s when Service Stations became Gas Stations!
My first experience with E10 failure was with my John Deere lawn tractor. Tractor would run fine for a while. When shut down it would not restart. Found the fuel line was collapsing internally due to Ethanol effect on the standard line. Changed to Marine grade line - problem fixed. Also, the fuel pump diaphragm rapidly deteriorated causing multiple replacements until John Deere changed the rubber specs.d Additionally, the Kawasaki engine valves would varnish quickly, sticking and bending the pushrod. Once I changed to Ethanol Free Regular that varnishing problem ceased.
Then there the fact Ethanol 10 fuel is less efficient than Regular gasoline. Better gas mileage is achieved via Regular Gas verses Ethanol 10 due to the energy (BTU’s) per gallon.
GGE calculated for gasoline in US gallons at 114000 BTU per gallon,
or 7594 kilocalories per litre[2]
Fuel: liquid, US gallons GGE GGE % BTU/gal kWh/gal HP-hr/gal kcal/litre
Gasoline (base)[3] 1.0000 100.00 114,000 33.41 44.79 7594.0
Gasoline (conventional, summer)[3] 0.9960 100.40% 114,500 33.56 44.99 7624.5
Gasoline (conventional, winter)[3] 1.0130 98.72 112,500 32.97 44.20 7496.5
Gasoline (reformulated gasoline, E10 - ethanol)[3] 1.0190 98.14% 111,836 32.78 43.94 7452.4
Gasoline (reformulated gasoline, ETBE )[3] 1.0190 98.14% 111,811 32.77 43.93 7452.4
Gasoline (reformulated gasoline, MTBE)[3] 1.0200 98.04% 111,745 32.75 43.90 7445.1
Gasoline (10% MTBE)[4] 1.0200 98.04% 112,000 32.83 44.00 7445.1
Gasoline (regular unleaded)[5] 1.0000 100.00% 114,100 33.44 44.83 7594.0
Diesel #2[5] 0.8800 113.64% 129,500 37.95 50.87 8629.8
Biodiesel (B100)[5] 0.9600 104.17% 118,300 34.80 46.65 8629.5
Biodiesel (B20)[5] 0.9000 111.11% 127,250 37.12 49.76 8437.7
Liquid natural gas (LNG)[5] 1.5362 65.10% 75,000 21.75 29.16 4943.3
Liquefied petroleum gas (propane / autogas) (LPG)[5]1.2470 80.19% 91,500 26.82 35.95 6089.8
Methanol fuel (M100)[5] 2.0100 49.75% 56,800 16.62 22.28 3778.1
Ethanol fuel (E100)[5] 1.5000 66.67% 76,100 22.27 29.85 5062.7
Ethanol (E85)[5] 1.3900 71.94% 81,800 24.04 32.23 5463.3
Jet fuel (naphtha)[6] 0.9700 103.09% 118,700 34.44 46.17 7828.9
Jet fuel (kerosene)[6] 0.9000 111.11% 128,100 37.12 49.76 8437.7
Nitromethane fuel ~2.3 41.23% 47,000
Ethanol 10 also has a greater affinity to hold water than Regular gasoline. That’s the main reason E10 is restricted from use in General Aviation aircraft.
If Ethanol Free - Regular gasoline is available in your area take the time and do a comparison on how well your (car/mower, etc.) operates.
Also, if you sell fuel that’s less efficient who benefits? The tax man ! ! !
Just my 2 cents…
Happy Motoring,
Dick
'74 OTS
'99 XJR
1947 Stinson 108-1 “Voyager”
Grow Old is Mandatory… Growing UP is Optional…
